wt.system.err wcadmin - Caused by: wt.workflow.definer.InvalidEventException: null event
wt.system.err wcadmin - at wt.workflow.expr.WfExpression721.executemethod_1(WfExpression721.java:61)
wt.system.err wcadmin - ... 19 more
root wcadmin - Queue entry number: 222 java.lang.reflect.InvocationTargetException
There is an exception in the workflow expression, check the customization code
thanks, customization team is currently investigating
