I have have navigated to the information page of a part and selected the 'Structure' tab -> and opened any part then it opens in a window with 'Structure' tab selection by default . Now I need to open the window with 'Details' tab selection.
Hi @vganugapenta,
This behavior is because of Client Stickiness. You can refer to "Client Side Stickiness" section in following help center document. There is a way to override the tabSetKey but that might not allow you to change the current behavior.
Bhushan
