invoke task, report template with servlet odata, change criteria
mmancin
Hi all,
   i've tried to call this servlet
POST /Windchill/servlet/odata/IE/InvokeIETask
with this body
    "Task": "com/ptc/windchill/enterprise/report/ExecuteReportTemplate.xml",
    "Params": [
            "Name": "object_ref",
            "Value": "wt.query.template.ReportTemplate:6852467828"
now I need to change the report criteria directly from the API. I tried to add a parameter but it doesn't seem to work.
For example (but it doesn't works)
    "Params": [
            "Name":"where",
            "Value":"((Associated Part.Latest Iteration equals 1) AND (Part Master.Number in 1234))"
Where can I find documentation? what is the correct parameter?
0 REPLIES 0
