Hello All,
We plan to move to Windchill PDMLINK 12-1-2-0 from PDM Essentials 11.1.M020
This will be a fresh install from scratch on a new Windows VM
Windchill 12.1 does not have Directory Services. (WindchillDS).
How do we connect to LDAP or AD in PDMLink. Is there any document to be referred here?
Thank you!
It is similar to connecting to Windchill DS, however there are other considerations in upgrading
During your upgrade, follow CS337415 - this will help you properly move the administrative ldap to the database.
If your enterprise ldap uses LDAPS then you will also need to import the AD server's certificate into the Windchill java keystore
