logout functionality in Windchill??
sghongade-2
7-Bedrock
hello everyone,
there is any method or process to logout the user form windchill?
one scenario is there is one system on which multiple user work, they want to logout the session? but they close the session every time for a user?
thanks in advance
5 REPLIES 5
There is a product idea for this:
Windchill needs a "Logout" feature
The discussion in the comments section has some ideas on workarounds.
If your Windchill system is using basic HTTP authentication there is no OOTB  way you can have a logoff button. There is a workaround, pushing an alternate authentication session clearing the current authentication (false authentication)
Windchill 10.1 + has form based authentication which will provide a log out button.  You can enable  it by following the methods detailed in http://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=WCAdvDepAuth_ConfigAltAuth&action=show under Form-Based authentication. If you are using WGM or DTI, there are couple of other things which you should change as well.
Thank you
Binesh Kumar
Barry Wehmiller
You should take a look here: Windchill needs a "Logout" feature
LoriSood
23-Emerald I
(To:sghongade-2)
Shravan,
Currently, log out functionality is only available with form-based authentications as Binesh Kumar‌ mentioned. Would it be okay to mark his answer as correct?
If you are using Internet Explorer you can select File>New Session.  This will create a new Internet Explorer window that will "forget" the login of the already-open window, thus allowing more than one person to log into WC at the same time from the same computer.  I usually use this for running tests and haven't seen this practice used in production so I cannot comment on if it has any issues or not.
