<auto generated name>
davehaigh
We have autonumbering turned off, but after upgrading to 10.2 the name field is now showing <auto generated=" name=">.
PTC is trying to tell us that this is per specs. I find it hard to believe I can't turn this off with some setting in Windchill or Creo.
The OIR's have not changed. 9.1 doesn't show this.
[cid:image001.png@01CFD7FC.DFB64AB0]
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
TomU
(To:davehaigh)
Does it auto generate if you leave it blank? If not, then I would push back on PTC for misleading information. Ask them to show you where the spec. says it should say it will auto number and then not do it.
