In Relex 2011, Quality Solutions,Windchill, Fault tree module
I can start a FTA but then get a Login failed for user 'faulttree'.
I can close the alert box and continue working for awhile then it returns.
this cycle repeats.
I can create a new project, create a system file under that project and name it, but I cannot get it to open.
Hello Dan,
Have you contacted technical support regarding this? This sounds like something that would be addressed through Tech Support. You'll want to get a Tech Support ticket as a starting point.
