null value as default for attribute with list
rdrennen
Is there a solution for a soft type attribute in a object with a
discrete set constraint to have the default value blank or null?
If the attribute is a value required constraint and the default value is
blank or null, then it would force the user to select a value from the
list.
Presently I can not find a method to establish a default value of blank
for a discrete set constraint.
Ray
Ray Drennen
MCAD Administrator
Otis Elevator Company
5 Farm Springs Rd.
Farmington, CT 06032
860-676-5619 - voice
860-353-1356 - eFax
ray.drennen@otis.com <">mailto:ray.drennen@otis.com>
bobg
(To:rdrennen)
I too need this functionality. Is there a way to achieve it?
Many thanks.
RandyJones
20-Turquoise
(To:rdrennen)
In Reply to Raymond Drennen:
list.
Ray
Ray Drennen
MCAD Administrator
5 Farm Springs Rd.
860-353-1356 - eFax
Set the "Default Value Display Mode" preference to "Do not display". This preference can be found under "Attribute Handling".
This can be achieved by configuring
Wt_home\codebase\config\logicrepository\xml\AllClients.xml
For an example
I created a soft type document com.swasen.Document and have a soft attribute
doctype that has a discrete set constraint.
1. Create a soft attribute doctype with data type String
2. Create a soft attribute com.swasen.Document
3. Add the soft attribute doctype to com.swasen.Document
4. Add a discrete set constraint |Type A|Type B|Type C. Also add a value
required constraint as this attribute needs to be specified when
create/update
5. Set the default value to Type A and save & check-in
6. Configure the AllClients.xml as below. Within <logicrepository> add a
element group for com.swasen.Document as below
<elementgroup>
<logiccontext<br/>dataType="WCTYPE|wt.doc.WTDocument|com.swasen.Document"/>
<objectattributes id="ObjectAttributes">
<attributeeditfield id="IBA|DOC_TYPE"&lt;br"/>defaultValueDisplayMode="none"/>
</objectattributes>
</elementgroup>
Upon bouncing the tomcat and method server, create/update of
<">http://www.swasen.Document> www.swasen.Document UI shows a blank value for
the doctype.
Hope this helps.
Thank you and have a great time.
Best Regards
Swamy Senthil
Principal Solutions Architect
973 216 0456(M); 973 324 2729(W); 866 908 6561(F)
Work Email: swamy.senthil@swasen.com
LinkedIn Profile:
bobg
(To:rdrennen)
Many thanks Swamy, that did the trick.
