query builder report - family tables with instances not at same revision as generic
MikeLockwood
22-Sapphire I
Recently I had to find all family tables in our system in which any instance did not match the generic.  This .qml does not have a criteria to find this, but finds all needed info and I was able to filter in Excel using text functions.  Provided just in case anyone else can make use of it.
The attached file is named for a tech support case.
I'd still be interested if anyone can come up with a way to filter for revision of instance not equal to revision of generic.  Didn't work very hard on this - I'm a wizard for these things in Excel.
7 REPLIES 7
Try with attached QML.
Hope it helps !!!
Shreyas
MikeLockwood
22-Sapphire I
(To:satre-2)
I don't see any difference.  note: Improved a bit since posting, but still getting results that are not latest Rev for some instances.  Latest that I have attached.
Report works for me as expected see below screenshot.
There some problem with sub select. You don’t have criteria
STEVEG
(To:satre-2)
You only get Sub-Select when you are site admin.
Got it working - see attached
