"Execution Control" and "Linked deliverables with project activities"
RT_10653138
Version: Windchill 12.0
Use Case: Project Link - New Project Creation - Execution Control &Linked deliverables with project activities
Description:
How can we enable the "Execution Control" and "Linked deliverables with project activities" in the new project creation wizard?
Which Windchill version are you in?
I would first check the Layout of the Project Type , and check in the "New" page layout wizard..
In case you could not crack it there., then.,
I think if you set these intended values in your source template for the project, it should be carried over for new instances from the template.
Cheers
Hari
