"/netmarkets/jsp/history/iterationHistory.jsp" not found
lgrant
Anyone know what could be the problem that giving me this error:
Page could not respond: /netmarkets/jsp/history/iterationHistory.jsp
org.apache.jasper.JasperException: File "/netmarkets/jsp/history/iterationHistory.jsp" not found
I see the iterationHistory.jsp file in the folder.
C:\ptc\Windchill_9.1\Windchill\codebase\netmarkets\jsp\history
Happens occaisionally with various pages for me too. I've never had the time to look into it and just end up restarting Tomcat if refreshing the page doesn't work.
lgrant
(To:lgrant)
At the same time Tomcat was stopped I deleted the \work file.
Did the trick.
jessh
(To:lgrant)
Deleting /work isn't related here.
The secret is likely quite simple: you're using an old Java 6 release whose JIT compiler has a serious bug on x86 hardware. The problem will likely only occur when the JIT compiler decides to compile the wrong thing -- which can take days of uptime, but could happen far more quickly depending on system usage.
Move to a recent Java 6 Update and this should go away.
