restart windchill with error
LG_10930214
FATAL [main] wt.method.server - MethodServerMain abort
wt.util.WTRemoteException: Unable to register server; nested exception is:
 java.lang.SecurityException: access denied
Did you clone the environment from source before upgrading?
It seems that you have not modified the following information:
  • java.rmi.server.hostname property in the wt.properties file
  • Hosts file:
    • etc/hosts for Unix platforms
    • C:\Windows\System32\drivers\etc\hosts for Windows platform
Please confirm above!
Refer to:
Article - CS389130 - Server cannot be stopped with an error: wt.util.WTRemoteException: Unable to register server; nested exception is: java.lang.SecurityException: access denied in Windchill PDMLink (ptc.com)
Solved: Re: java.lang.SecurityException: Access denied - PTC Community
Article - CS150162 - ServerManager throws error Unable to register slave cache in Windchill (ptc.com)
Can you share more of the stack trace?
What OS are you on? Spit balling as we need more information. Could this be file access related? Installing as root but running as another user? Could this be services like SELinux or fapolicyd? Could this be Java certs issue (less likely)?
I have even seen similar on an out of memory error, or maybe an expired SSL cert
  • Hosts file:
Refer to:
