sql link "modified by" and wtpart(master)
rvanveerdeghem
11-Garnet
Does somebody know in which table I can find the "modified by" for a wt.part.WTPart?
And maybe the link with the table wtpart or wtpartmaster?
Thanks in advance
kind regards
Ruben
Ruben Vanveerdeghem‌,
It is surprising nobody has responded yet.  By now you have probably gotten your answer.  But if not, this might be helpful (for Oracle db query):
select
  m.wtpartnumber,
  p.VERSIONIDA2VERSIONINFO rev,
  p.ITERATIONIDA2ITERATIONINFO iteration,
  u.name modified_by,
  p.MODIFYSTAMPA2 last_modified
from
  wtpartmaster m,
  wtpart p,
  wtuser u
where 1=1
  and m.ida2a2 = p.IDA3MASTERREFERENCE
  and p.ida3b2iterationinfo = u.ida2a2
  and m.wtpartnumber = 'XYZ'
order by
  m.wtpartnumber,
  p.ida2a2
select
  m.wtpartnumber,
  u.name modified_by,
from
  wtpartmaster m,
  wtpart p,
  wtuser u
where 1=1
order by
  m.wtpartnumber,
  p.ida2a2
