trying to install CPS18 in 12.0.2
rleir
Have got the PSI installer contained in CPS18 running, with LAX_VM $JAVA_HOME/bin/java
and with PATH extended to include Windchill/bin.
Also have a link to Corretto Java as
export JAVA_HOME='/opt/ptc/Windchill_12/Corretto11'
java -> /opt/ptc/Windchill_12/Corretto11/
But the Update icon is greyed no matter what I do.
Found the logfile for this in /tmp/user/PTCSOLNINSTALLER_PtcInstall.log containing 140K but no errors that I could see.
I found the psi_iir_index.xml file now. That's a clue: it is in a directory named PSI-Main. Maybe I need to cd to the parent directory before running the installer?
avillanueva
23-Emerald I
(To:rleir)
Are you installing as the same user who installed Windchill previously? Seems like it does not know where in install registry from before is.
avillanueva
23-Emerald I
(To:rleir)
RandyJones
20-Turquoise
(To:rleir)
Like Tony says you must run the installer with the same user it was previously ran with.
The installer is looking for ~/.ptc/windchill/psi_iir_index.xml
The contents of that much match up with a directory under PSI/installer/instreg
Will have name of something like
PSI/installer/instreg/ii-615d6,<some other chars>/
HelesicPetr
(To:RandyJones)
@rleir
Or you can recreate the missing psi_iir_index.xml file in the correct local folder location.
I did it many times
PetrH
rleir
(To:rleir)
@avillanueva @RandyJones @HelesicPetr
Thanks team! All your answers are 'Solution'.  Chose first, would like to choose all.
Also useful: https://www.ptc.com/en/support/article/CS37842 "Update Existing Installation" or "Install Optional Component" option is disabled in PTC Solution Installer (PSI) when trying to update Windchill
