Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
webject Exception :'only DiscreteSet values can be used for InstanceIndentifire query criteria '
I need to find out change notices which some of the activities (i.e. Audit Change Notice .etc.) happen between start date and end date. I prepare Webject (see Attachment) which works on our Development server but gives ‘only DiscreteSet values can be used for InstanceIndentifire query criteria ‘ exception onQA server.
