Team,
The WGM config file wgmclient.ini is located in the Windchill Workgroup Manager home directory, which is under C\Program Files\ so admin privileges are needed to modify it.
Is there a way to override it using a file somewhere else, preferably in the users' folders?
cheers -- Rick
The wgmclient.ini can be read from the folder specified by the environment variable PTC_WGM_STARTUP_DIR, if a wgmclient.ini file exists in there it takes presidence over the one in program files. Usually that folder is a subdirectory of the wgm_root though.
Hi @rleir
If you install WGM you can set location where the application is stored.
So I guess that if you change installation location then also ini configuration file will be out of the Program Files folder.
PetrH
