why using PersistenceHelper.manager.store/update will become more and more slow
ptc-3852385
By using PersistenceHelper.manager.store/update to exchange the external data into Windchill, it seems that the performance of these API will degrade along with the time. Once the method server restarts, the performance rewinds to be good but will still follow the same negative trend.
One idea is that "com.ptc.netmarkets.serverCacheEnabled=true/false" is the cause, but according to the test, it is in fact not.
Anyone has encountered the same situation and has eventually a solution ? Thanks in advance.
Are you testing this within a transaction?
-Ste
