hi guys,
I am working the modelling of the objects in Windchill 10 F000. I am not able to compile the Java class. I just copied the code from the Customizer's guide. can anyone help me out?Please give me the steps to be followed. Guide is no more useless( sorry guys)
WC10 modelling is different from WC9x . Rational rose no more.
thanks
yes I use the same path to compile the Java file.
For example ,
I created Test.java file where I implemented the logic. Do I need to create the _Test.java file also in the same directory?
I found the solutions, Yes, We need to install the Information Modeler and it is working fine for me.
Thanks guys for all your replies
