wt.doc.WTDocument:7784899724
AA_11007139
I am using Windchill PDMLink Release 11.1 and Datecode with CPS F000
error "wt.doc.WTDocument:7784899724" during removing document DSH00008647 from many parts. we can't make any update to parts due this message error the same message when i launched loader remove link of document ( Message;partType;View;partID;partRevision;docType;docID;docRevision;partner;Link Removal The object with the following key was deleted or inaccessible: "wt.doc.WTDocument:7784899724";SupplierPart;;A300752500;;Datasheet;DSH00008647;;V501644--COFICAB TUNISIE SA;Yes )
I think we need more information than this. What operations occurred when this message appears? Screen shots? Based on what I see, it speaks to a broken link in the database. Is it some parts or all parts? Was there any manipulation of the database or customization running which could account for this?
AA_11007139
(To:avillanueva)
hello,
If possible, could you please organize meeting to share you the issue in our system.
Hello AA_11007139,
Is it possible to share the MethodServer log showing the error ?
KR,
Charles.
BenLoosli
(To:AA_11007139)
You should probably open a case with PTC Technical Support as they can use Teams and see your machine.
The Community is a group of users helping other users and we do not have those tools available to us. If we do, I doubt any user will connect their system to yours.
