New feature parameters in sheetmetal
JoeFrancz
2-Explorer
I just ran across two new parameters in sheet metal design :SMT_FLAT_PATTERN_HEIGHT and _WIDTH...Anyone know how to use these? I tried addting the relation that is specified in CS162831 and no luck. Thanks for the help
Creo 2.0 M120
AndyHermanson
(To:JoeFrancz)
When you are adding the parameter to the relations, make sure your are tying it to the feature.
[cid:image002.jpg@01D00581.C54CD010]
Or you can tie it to the feature ID manually.
[cid:image006.png@01D00581.C54CD010]
Either way it should look like the about in your relations. You MUST include the ":FID_xxxx" to tie it back to the features parameters or it will be looking for the parameters in the overall part and won't find it.
Andy Hermanson Engineering Design Applications
Phone 605-275-1040 ext. 51114 | Mobile Phone 605-310-8168
Address 201 Daktronics Dr. Brookings, SD 57006
Web daktronics.com Twitter<">http://www.twitter.com/daktronics> YouTube<">http://www.youtube.com/daktronicsinc>
[email-signiture_logo]
In Reply to Joe francz:
Creo 2.0 M120
