Greetings,
This has been asked many times before, with most of the requests not being responded to, at least in a posting. I thought I'd try again...
My company recently noticed that the material files they had been using were very suspect regarding the accuracy iof the values in the files themselves.
My question is this - does anyone have a complete/accurate set of Creo compatible material files that I can populate to my company's library? I've got to believe there is someone out there who had already encountered this issue, and has assembled a set, hopefully a set they'd be willing to share?
I kniow about MatWeb, but am hoping to not have reinvent the wheel...
The files can be either in .mtl or .mat formats, as I can covert the .mat files if need be.
Thanks in advance if you happen to have something you'd be willing to share.
Happy Holidays!
Gary S.
I came across these material files (~100). They look quite useful. They are in the .mtl file format (same as Creo), and could be added directly into the creo_loadpoint\text\materials_library folder.
