Hi
1. can i do a static stress analysis simulation on 2 wlded parts (i have added the welding feature with the "application" module out of the understanding that maybe this is the only way CREO can do the simulation)
- if not, what is the best way to do it ?
I guess it depends:
As of Creo 4.0 you can create a solid weld, this behaves better in Simulate than the surface welds.
