Axes printing
RaphMORIN
Axes printing
Hi all,
Something I'm wondering since a long time now and would like to solve.
On my drawings, the axes look this way. It's fine. It intersects as it should be.
When I want to print, it looks this way (this is a screenshot from the preview in Creo, but it looks exactly the same once printed on paper). Why ? This is not very conventional. Is it possible to print the same way it looks on the screen.
as far as I can remember axis printing pattern is dependent on drawing format size.
You can set exact size of axis printing pattern using line_style_length drawing option.
See:
http://www.proesite.com/cgi-bin/find_option.cgi?srch=line_style_length&ver=creo1&mode=drwsetup
http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/detail/Axis_Display_Options.html
MH
Martin Hanák
Did u solve this matter?
I faced the same matter as u, can you give me the solution?
Thanks in advance.
