PhotoLux Render Issues
BulldogFan7
7-Bedrock
Windows 7 Ultimate 64-Bit
8GB RAM
NVIDIA GT 550M
Creo Elements Pro 5.0
Every time I try to render using PhotoLUX, the result is a solid black screen. I can render using PhotoRender but the quality isn't that great.
I have tried every scene, moving floors/walls/etc, adjusting lights, adjusting effects...all with the same result.
I have tried Draft to Maximum quality. Output Full Window to JPEG to TIF...all the rendered files are solid black. It's driving me insane! I've followed as many tutorials as I can...step by step, but my result is solid black as opposed to the tutorials results of a completely rendered model.
Has anyone experienced anything like this? Have any Ideas?
Any help will be greatly appreciated!!!
Ok everyone...I finally figured it out. It was McAfee Internet Security. Not sure how it blocked it but as soon as I uninstalled McAfee, the rendering works perfectly.
Wish I knew this from the get go.
16 REPLIES 16
That´s weird you should check maybe your materials, i recomend to use only PhotoLUX scenes and materials (the last ones), your computer is perfect.
I went back to check all my materials...and I am using PhotoLUX visual styles and am using a PhotoLUX scene.
It's frustrating because I'm following all the instructions i can find online and it still is not working. I'll post a picture of what it looks like when I render a small section.
Here are some screenshots that may help anyone determine what settings I have wrong...or what else I need to look at.
This all started when I went to create a nice little Happy New Year impage for the company I work for. Now it's becoming a mission to figure this out.
When I do just a Render Region, below is what I get. If I render it completely, then the entire output is black.
Everithing is ok but i see the quality on draft
Also try "render to" .jpg or other kind of pictures extensions and chek that the model isn´t below the floor
I have it set to Draft right now it doesn't take so long to test. I have tried High & Maximum.
Also, I have set my output to New Window, JPEP, TIF, PNG...pretty much every option. They all turn out solid black.
What is weird is that even though the picture file is solid black, the file size is HUGE!
I really don't know what to do. So frustrating!
Totally weird be carefull that the model is above the floor
I hit the button to align the floor to the bottom of the model.
I made that mistake once while using Photorender.
Or the face of the model is with the floor on front
Floor nor walls are causing the issue...they are not in front of the model.
Also...I'm looking in Floating Modules and I don't see where there is an Advanced Render option. Should that be there?
Did some advice appear when you select PhotoLUX?
No, there was not advice. Other than it being black, PhotoLUX works fine.
so rare unlucky guy
Cool man finally hehe.
