Hi all, i need to retrieve back previous iteration of a model in windchill. ie to my model there is 3 iterations in commonspace. I need to use the 1st iteration of the model again. How to retrieve without any loss. Guide me
Hi Vivek,
go to preferences (Site or Org) and expand the "Create and Edit" group. Enable the option "Allow checkout of non-latest iterations".
Björn
Hi Bjoern,
Thanks for the reply. But i couldnt find the option in my preferences (see the snap below). I searched and couldnt find "Allow checkout of non-latest iterations" any where. Am using windchill 10.1. Can we sort it out in some other way?
Vivek
Hi Vivek,
you have to be organisation or site administrator to set this option.
Then you can choose your Organisation --> Utilities --> Preferences --> ....
Björn
Hi Bjorn,
You are right. Also i dont have those previliges
Is there any other way you know?
Thanks a lot for your replies buddy
Hi Rajan,
there is no other options. You have to be an administrator to set this option.
Björn
You can try the following:
1) Check out the latest iteration of the object in question
2) Open the previous iteration from Creo or Pro/E ("As stored") and click Save
3) You'd get warning that the object is already in Workspace, select Overwrite
4) Check in
