How to view all users logged into Windchill?
kregimbald
I would like to be able to see a list of users that are logged into Windchill. Does anyone know how I can access this information in Windchill 10.1?
There is no way to do this directly. The only option is to look at the status of the license and for that you will need to run ptcstatus.bat. this will show you who is using licenses
BenPerry
(To:kregimbald)
This is working for me on Unix in 9.1 and 10.2.
  1. From a Windchill shell, type jconsole.
  2. Connect ServerManagerMain.
  3. Drill down to com.ptc > Monitors > Active Users > Attributes.
  4. On the right pain, double-click on java.lang.String[#].
There is also a PTC document that shows a different location for this. The PTC document is only looking at the users connected to a specific MS. CS146093.
I'd be interested if this works for you. I cannot remember if this is something we had to set up or it was OOTB. It would also be nice if this information was passed through to Server Status in the UI instead of having to go jconsole into on the server to find it.
Message was edited by: BEN PERRY. I forgot to add the link to the PTC document.
