Check if image exists
  • July 23, 2019
  • 9237 views
I would like to check if app/resources/IMAGES/Filename.JPG exists or not, and then display scrolling arrows (left and right) if multiple images exist. I can figure out the scrolling arrows, and how to change the 3D image widget, but I can't find a way to check if JPG files are uploaded. I display a different image for each step of an animation, but some steps will have multiple images associated with them.
I have tried Stack Overflow: Check synchronously if file/directory exists in Node.js
but I get the error in my console "TypeError: Cannot read property 'access' of undefined"
var name = // code I use to concatenate a filename string ending in .jpg
var p = "app/resources/IMAGES/"+name;
 fs.access(p, error => {
 if (!error) {
 console.log("exists: "+p);
 } else {
 console.log("does not exist: "+p);
Any suggestions?
Best answer by Wes_Tomer
I finally got it working yesterday. Instead of creating a for loop, I make the function run itself again each time it receives a response. Of course, this could go on forever. So I built in a variable called "proceed" that is true or false. Once a limit has been reached (such as 10 photos per step) the loop stops. That's more or less how my code is working. It's a nice trick -- when you want to "pause" a function until something happens, just put the function call inside of the function in order to create a loop:
var proceed = true;// change back to false later
var waitUntilFinished = false;
var j = 1;//step
var k = 1;//image
var X = []; // [[chapter1 1,1,1,3,4,1,1,3],[chapter 2, 1,1,1,1,1,2],[chapter 3, 1,1,1]]
var Xm = []; // metadata for X
// Change Image per step
$scope.app.stepImage = function (Achapter=1,Astep=1,Aimg=1){
 $scope.view.wdg['U-20-1']['src'] = 'app/resources/IMAGES/CH-'+Achapter+'_STEP-'+Astep+'_IMG-'+Aimg+'.jpg';
 // below is code for finding out if multiple images exist per a step, and if so, showing arrows
 if(Xm[Achapter-1]===undefined){
 waitUntilFinished = true;console.log("**a** X=");console.log(X);
 proceed = true;
 $scope.app.getX(Achapter,Astep,Aimg);
 if(!waitUntilFinished){
 // control visibility of <[]> and image resource
 dispImgArrows(Achapter,Astep,Aimg);console.log("**c**")
// Show arrows if multiple images exist per a single step
$scope.app.getX = function(i=1,j=1,k=1){
 var j1=j;var k1=k;//capture original inputs
 if(j>chapters[i-1][4]){console.log("**d**");Xm[i-1]=true;proceed=false;i=1;j=1;k=1;waitUntilFinished=false;$scope.app.stepImage(i,j1,k1)}
 if(X[0]===undefined){
 for(ch=0;ch<chapters.length;ch++){
 X.push([]);Xm.push(undefined);
 for(st=0;st<chapters[ch][4];st++){
 X[ch].push(0);}}}
 if(proceed){
 var name = "CH-"+(i).toString()+"_STEP-"+(j).toString()+"_IMG-"+(k).toString()+".JPG";
 console.log(p);
 $http.get(p).then(successCallback, errorCallback);
 function successCallback(response){
 console.log("i="+i+"\nj="+j+"\nk="+k+"\nX=");
 console.log(X);
 k++;
 X[i-1][j-1]++;
 $scope.app.getX(i,j,k);
 function errorCallback(error){
 k=1;// reset
 j++;// step #
 console.log("chapters =");
 console.log(chapters)
 console.log(X);
So essentially when you go to a chapter you automatically trigger a function to (1) create an array with sub-arrays for each chapter. (2) populate the sub array for that particular chapter with a list of numbers representing the number of images for each step (3) populate a "meta-data" array Xm that tells you which chapters have been visited and thus the number of images per step has been recorded for them. So for instance, after visiting chapter 2 the variables look something like this X = [[0,0,0,0],[0,0,0,0,0,0,0],[1,1,1,2,1,3,1],[0,0,0,0,0,0,0,0,0,0],[0,0,0,0]] and Xm = [undefined, undefined, true, undefined, undefined]
If you want the simplified version of this (the core functionality for a recursive check) then use this code:
var j = 1; //step
var k = 1; //image
var Xm = [];
// by the way "chapters" is an array with chapter metadata, and chapters[i][4] tells you the number of steps for chapter # i
// this just creates an array X with placeholders [[0,0,0],[0,0],[0,0,0,0]] and Xm
 if(j>chapters[i-1][4]){;Xm[i-1]=true;proceed=false;i=1;j=1;k=1}
 X[ch].push(0);}}}
 if(proceed){
 k++;
 X[i-1][j-1]++;
 $scope.app.getX(i,j,k); \\ use this instead of a for loop
 k=1;// reset
 j++;// step #
Try this Function;
function doesFileExist(urlToFile)
var xhr = new XMLHttpRequest();
xhr.open('HEAD', urlToFile, false);
xhr.send();
if(xhr.status !="200") {
console.log("File not exist");
else {
console.log("File Exist")
doesFileExist('app/resources/Uploaded/FILENAME.ext');
I hope to be proved helpful
Giuseppe.
additional to suggested option by  @Giuseppe_Fiore
you can use also the $http service e.g. to check if a file (var below jsonFile) is in particular Studio folder:
 $http.get('app/resources/Uploaded/' + jsonFile).success(function(data, status, headers, config) {
 console.log("Found :"+jsonFile+" in folder app/resources/Uploaded/");
 .error(function(data, status, headers, config) {
console.log("Could NOT find :"+jsonFile+" in folder app/resources/Uploaded/");
OK , I see that here is the key word is in sonorously what I overlooked – so far I think the both suggested methods , which works fine are asynchronous calls
What is exact the problem  so that is necessarily  to use synchronous call ?
Maybe you can use some constucts with the promises as mention in the stack overflow post
