About WinDU patch WNC 10.1_M030
  • September 4, 2014
  • 3 replies
  • 962 views
Hi Fellow Windchillers,
AM in the process of installing a patch for WinDU and WinRU for Windchill 10.1 M030.
1. To install the patch 10.1-M0X0_WINDU_WINRU_PS6.jar have unzipped the contents into a folder and am running the following in windchill shell:
java -jar 10.1-M0X0_WINDU_WINRU_PS6.jar --install <windchill>
where <windchill> refers to the product installation directory where you are installing the patch
After completion of installation (log attached) on running "windchill version" it displays no patches are installed. Please help me for installing this patch.
Amol
Amol S. Akolkar
PhD Student-PLM Lab
COT-Computer Graphics Technology
Purdue University, West Lafayette-IN
Amol,
Make sure that you have the WindchillDS (directory server) service running before you install the patch.
Mike Ibosh
September 4, 2014
Below is the error, either user "amoladmin" does not have admin rights ( Windows permission ) or Windchill is running and Method server locked that file
java.io.IOException: Unable to move 'C:\ptc\Windchill_10.1\Windchill\srclib\pdml\DDLBasic-windu.jar' to 'C:\ptc\Windchill_10.1\Windchill\srclib\pdml\DDLBasic-windu.jar~original2204914747399996953' in order to replace it.
DEBUG 2014-09-04 12:52:33 - at com.ptc.windchill.install.ApplyJarDiff.replaceFile(ApplyJarDiff.java:172)
DEBUG 2014-09-04 12:52:33 - at com.ptc.windchill.install.ApplyJarDiff.run(ApplyJarDiff.java:97)
Hope it helps.
Shreyas
When you launch your "Windchill Shell" right-click and select "Run as
Administrator"
Then run your patch install command.
Robert N. Kennedy III
