Automated rehosting. Bugs and problems help request.
- May 12, 2014
- 25 replies
- 9376 views
Hello all,
I am attempting to do my first system rehost. I want to use the Windchill Rehosting Utility. I have fully read the guide and made detailed notes and the necessary configuration files. I must have missed something because I am receiving an error when I try to run. The error is:
[DBValidator] 2014-05-12 13:04:32,335 ERROR [main] com.ptc.wc.rehost.validate.DBConnectionValidator - Failed to validate db connection:[DBValidator] java.sql.SQLException: ORA-01017: invalid username/password; logon denied
My projects.properties contains:
# Defines the modules for each use scenario. Modules are separated using a comma.
#rename.modules=StartProcessTask:${rehost.script.task1},IERehostTask,StartProcessTask:${rehost.script.task2},DBRehostTask# rename.modules=IERehostTask,ApacheRehostTask,DBRehostTask,OrgRehostTask,StartProcessTask:rehost.script.task1,VaultTaskrehost.modules=StartProcessTask:StartProcessTask:rehost.script.PTCFolderCopy,StartProcessTask:rehost.script.LDAPImport,IERehostTask,ApacheRehostTask,StartProcessTask:rehost.script.ORACLEDBCopy,StartProcessTask:rehost.script.ORACLEDBImport,DBRehostTask,StartProcessTask:rehost.script.WindchillOracleStart,VaultTask,FileServerTask,InstallerRegistryRehostTaskMy renamed rehost.properties is attached. Note password lines are all referenced to encrypted passwords set by the setAuth.bat utility as directed in the Windchill Rehosting guide.
For the Oracle database connection I have verified both the PDMLink user account password and the system manager account password, and I have tried both with the setAuth.bat utility and re-ran the rehost.bat utility. Neither of these are successful.
I am working with PTC on this issue, but currently I am in a wait state so thought I'd reach out here for the record.
Has anyone successfully used the automated rehosting utility? If you have did you encounter this '[DBValidator] java.sql.SQLException: ORA-01017: invalid username/password; logon denied' error?
Thanks again!
