Config file problems
- June 5, 2013
- 5 replies
- 8128 views
To all you Windchill users:
We are on Windchill 10.0 M030, Creo 1.0 M050.
I recently updated the config file for all users (all are stored locally on each users C drive). The previous config file worked fine for all users.
The new config file is basically the same, with a few new options. For one of our users, after Creo startup, Creo will hang indefinitely (after user is prompted for the Windchill user/pass). This user is running on Windows 7, though the rest of the users also use either Windows 7 or Vista with no issues.
I can circumvent this problem by removing all the following config options that have the file path starting with wtpub://Windchill… :
template_designasm wtpub://Windchill/Libraries/Library/Formats/in_lbs_assembly_solid.asm
template_sheetmetalpart wtpub://Windchill/Libraries/Library/Formats/inlbs_part_sheetmetal.prt
template_solidpart wtpub://Windchill/Libraries/Library/Formats/inlbs_part_solid.prt
pro_format_dir wtpub://Windchill/Libraries/Library/Formats
start_model_dir wtpub://Windchill/Libraries/Library/Formats
pro_palette_dir wtpub://Windchill/Libraries/Library/Symbols
symbol_instance_palette_file wtpub://Windchill/Libraries/Library/Symbols/standard_notes.drw
Note, however, that the old config file also contained most of the above options, yet there was no hang after startup.
I have attached the old and new config files.
Anyone have any ideas?
Andri Ulrich
