Deleting Policy Administrator Rules
Thanks to previous posts in this forum, I learned how to use the "Load From File" utility to bulk-add additional rules in the Policy Administrator. I also noted (again, as described here), that I can't over-write or revise existing rules already in the system.
My question this morning is; Is there a utility or method available to bulk-delete all of the existing rules that I want to change?
If not, then I am faced with deleting themmanually on each of our Products before bulk-loading the new rules, and at that point, I sort of lose the advantage a bulk-loading script offers in the first place.
Thanks in advance for any advice you might share,
Steve
