How to revise WTPartDescribeLink
I have WTPart object with describe links WTDocuments associated with that.Now I need to revise the PartDescribeLink through code.
Below is the code I have tried so far..
Vector localVector=new Vector();
QueryResult localQueryResult=WTPartHelper.service.getDescribedByWTDocuments(part,false);
System.out.println("size is "+localQueryResult.size());
if((localQueryResult!=null)&&(localQueryResult.hasMoreElements()))
while(localQueryResult.hasMoreElements())
WTObject localObject=(WTObject) localQueryResult.nextElement();
localVector.addElement(localObject);
if((localVector!=null)&&(localVector.size()>0))
for(int i=0;i<localVector.size();i++)
WTPartDescribeLink localPartlink=(WTPartDescribeLink) localVector.elementAt(i);
WTDocument localWTDocument=localPartlink.getDescribedBy();
System.out.println("values are "+localWTDocument.getNumber());
RevisionControlled localRevisionControlled=null;
localRevisionControlled=(RevisionControlled) VersionControlHelper.service.newVersion(localWTDocument);
localRevisionControlled=(RevisionControlled) PersistenceHelper.manager.save(localRevisionControlled);
This code is revising only the WTDocument object but not the partDescribelink.If I tried to pass the Describelink object directly like this
localRevisionControlled=(RevisionControlled) VersionControlHelper.service.newVersion((Versioned)localPartlink);
means it is showing the following error message.
Exception in thread "main" java.lang.ClassCastException: wt.part.WTPartDescribeLink cannot be cast to wt.vc.Versioned
at ext.gt.test.CheckLink.getPartlink(CheckLink.java:94)
at ext.gt.test.CheckLink.searchPart(CheckLink.java:52)
at ext.gt.test.CheckLink.main(CheckLink.java:32)
I need to revise the link in code.Someone help me with giving the API or some example code snippets would be helpful for me.
Thank you
