Migration
  • April 27, 2010
  • 617 views
Has anyone loaded PDMLink on the same server as Intralink 3.4 then done their migration on the same server successfully?
TIA!
Of course if you use vmware or another virtual, you can have both on same box.
But I would assume the only other route is to have oracle hold both SIDs.
I would imagine your oracle version will be 10g or 11i. I am not sure you could import your
ilink 3.4 ilnk sid into your current oracle install.
I am not a oracle guru, so anytime I get anything to work, its by luck or trial & error.
I have had wc8 & wc9 in same oracle db on same box, but that was 2 different installs & I just
named the SIDs different names.
But tats fresh PSI & oracle installs. I don't know if an import of ilink 3.4 dump file would
work. I thought about trying, but didn't want to clean up the mess or go through the headache,
not knowing oracle well enough.
If some oracle/wc guru here knows if it will work & how, then I'm sure you could use just one
box for migration.
I would be interested in knowing if it can be done. I do many consulting services migrations,
so that could maybe help me in the future.
Along with many others.
Larry Jett
cadjett@aol.com,datajett@aol.com
