mount failed for replica
I am installing and testing Windchill for the first time, specifically Intralink 9.1 M050.
Master server install and setup worked fine, as did the install for the replica server.
I defined the host, vault, and root for the replica (on the master).
However, when I attempt to mount the folder for the replica, I get this:
Create mount for root folder "ogreplicafolder" failed.
Nested exception is: wt.util.WTException: Mount status cannot be determined
After the first attempt, I thought that maybe the folder must already exist, so I created it and tried again.
Same error.
Found nothing about this in PTC's knowledgebase.
Any advice?
Gerry
