Nov 5, 2024 10:41 AM UTC
New Basic Auth for Thumbnail Content URL
Version: Windchill 11.2
Use Case: Before we were able fetch Thumnails of EPM documents by getting the URL using a call as follows /Windchill/servlet/odata/v3/CADDocumentMgmt/$metadata#CADDocuments('OR:wt.epm.EPMDocument:')/Thumbnails and then using this URL (/Windchill/servlet/WindchillGW/wt.fv.master.StandardMasterService/doDirectDownload/...) as a image scr in a Webapp to display the Thumbnail
Description:
With the newest CPS Update 17 the Thumbnail-URL changed to <Windchill-Server>/Windchill/servlet/WindchillAuthGW/wt.fv.master.RedirectDownload/redirectDownload/... which expects a Basci Authentication.
This situation makes the integration of the Thumbnail a lot more complicated and thats why I'm wondering if there is another option like having (configuring to have) a temporarly valid URL to fetch the Thumbnail as before like a lot of other Content Providers do.
As to retrieve the URL needs authentication already such a temporary url should not be a security issue.
I am lokking forward to read from anybody concerning my issue.
Best, Gregor
HelesicPetr
Nov 6, 2024 10:10 AM UTC
Hi @Greg75
I always used the basic authentication if I call any download from Windchill so it should not be so big deal.
PetrH
Greg754-ParticipantAuthor
Nov 6, 2024 10:46 AM UTC
You do this from the front- or the backend? Of course - technically this is not a issue - but the credentials should not be available in the FE and handling this through the BE is producing quite a overhead.
HelesicPetr
Nov 6, 2024 11:40 AM UTC
Hi @Greg75
Backend always backend. Users can not see any credentials used background.
PetrH
Nov 6, 2024 9:24 PM UTC
After this change I've added an additional httpRequest on my backend to fetch preauthorized thumbnail as it was before:
			if (latestReleasedPart != null && latestReleasedPart.size() > 0) {
				String thumbnailUrl = getThumbUrl(latestReleasedPart.get(0));
			 HttpClient client = HttpClient.newHttpClient();
			 // Create initial request with authentication header
			 HttpRequest httpRequest = HttpRequest.newBuilder()
			 .uri(URI.create(thumbnailUrl))
			 .header("Authorization", auth.getAuthHeader())
			 .build();
			 // Send initial request
			 try {
					HttpResponse<String> resp = client.send(httpRequest, HttpResponse.BodyHandlers.ofString());
					 if (resp.statusCode() == HttpURLConnection.HTTP_MOVED_TEMP) {
					 String redirectUrl = resp.headers().firstValue("Location").orElse(null);
					 if (redirectUrl != null) {
					 	System.out.println(redirectUrl);
					 	respUrl.thumbURL = redirectUrl;
				} catch (IOException e) {
					// TODO Auto-generated catch block
					e.printStackTrace();
				} catch (InterruptedException e) {
