Sticky Workflow Reassignments?
- September 21, 2010
- 2 replies
- 1349 views
For instance, I have a final approval stage. At this stage the approver
can select "Approve" and release the documents or select "Rework" to
send the task back to the designer for him to make changes. This works
great; however at times a manager (Manager 1) is in charge and when
Approval tasks come in, he needs to reassign those to a more pertinent
manager (Manager 2). If he does this, it works and the other guy will
get the assignment BUT if rework is done and the task is sent back to
for approval a second time, then the initial manager (Manager 1) gets
the assignment and then he has to again reassign the task back to
(Manager 2). So my question is, if I reassign a task to someone, is
there a way to ensure he keeps getting that task for the duration of the
workflow?
What other strategies might be better here?
Using PDMLink 9.1 M050
Thanks in advace!
Tim Oliphant
Lead Project Engineer
(206) 394-3542
www.RedDotCorp.com
Because some email programs may block email from Red Dot, we ask that
you arrange with your email manager to allow ALL communications from us
(@RedDotCorp.com) to pass unhindered through your firewall.
workflow?
Thanks in advace!
Tim Oliphant
(206) 394-3542
www.RedDotCorp.com
