Version (Design)?
  • February 12, 2013
  • 747 views
All -
I was reviewing our Publish Monitor queue and noticed some odd Version numbers that had "(Design)" after the number. I looked up one of the part numbers, and there is no such version in the assembly's history. (see attached)
It doesn't appear to be causing any problems, but I wonder if anyone has seen this before and knows what might be creating it?
Thanks in advance -
Chrystal Johnstone
Red Dot Corporation
objects with (Design) are the wtparts which may not always be the same version of the respective epm docs
associating a document to a wtpart will update the iteration of the wtpart but not effect the epm docs. so if you serach for the epm doc that particular iteration may not exist.
