Animation - how too?
This seems a good a place as any to open a discussion on Animation.
I have core Creo and learned a bit about animation control.
I have since learned a lot of the limitations to creating animations.
I'd like to see some of your creations. Also know who has a solid handle on this function.
I did a little fabrication sequence of a small aluminum sqill'd stem for a bike mirror.
These are things I learned rather quickly in making this video:
- Animation is not available in Part mode. Only Assembly mode.
- Perspective views are very difficult to manage and cause strange behavior in view interpolations.
- Transparency interpolations ignores surface appearance assignments.
- Assembly surface appearance do not display transparency
- Part surface appearance is removed.
- You cannot apply Style to patterned parts and expect them work.
- Animating part fabrication is not the primary purpose of this application.
- I haven't found a way to activate a section in the sequence.
Share your battle scars and your victories
