Can you force sketch dimension to be angular?
  • May 4, 2016
  • 10 replies
  • 10491 views
Every once in a while I run into a situation where I need to add an angular dimension to a sketch and it wants to change it to linear.
The problem appears to be that the angle is less than a degree.
Here is the sketch prior to adding the dimension.  There isn't a lot of difference of height but there is a difference.
Here is what happens after the dimension.  You can see that the shading hasn't updated on the right corner.
How do you force an angular dimension?
Best answer by rzukowski
Try the config.pro option:
minimum_angle_dimension
I have mine set to 0.1
Rick Z.
Hi Paul,
The workaround to adding angular dimensions for very small angle is to create an angular dimension from some other reference (maybe a normal plane or ref) which gives a bigger dimension. Then we can just select the dimension & use replace command to change the reference to desired one.
Pushkar
StephenW
The way I do it is to create the sketch with a much larger exaggerated angle, add the angle dimension and then change the angle dimension to the desired small number.
rzukowski13-AquamarineAnswer
Rick Z.
pimm15-MoonstoneAuthor
Actually everyone's answer here is correct.
I like your answer Rick because it doesn't require the slight work around.
I tried searching for a config.pro option on this by searching by angular instead of angle prior to asking this question.  In the past I've left the sketch partially unconstrained, but sometimes that doesn't work out well.
Finally this works the way it should!  Thanks.
I have a 0.2 degree angle and after changing the config.pro to "minimum_angle_dimension 0.1" I still cannot get the dim to place properly.  I have tried everything I can think of including zooming way out and in.  Prior to Creo you could zoom in real closely and it might flip the dim to angular.  I tried a dummy line and edit attachment as well as selecting a datum that was far enough away that Creo might see it as an angle.  Edit attachment after using a dummy line just sent the dim back to linear.
