Creo View Improvements
- Better way to view Cable Designation's from Creo Parametric other than showing the value in the metadata for each part when published as a standard publish.
- Can this be obtained from a positioning assembly publish?
- Search:
- Not very user friendly. CTRL F doesn't search attributes even though the UI implies it does
- Mobile:
- Creo View needs a better mobile/tablet solution
- Windows 8.1/10 Pro on mobile should have a UI change to make buttons bigger to use with fingers instead of just the mouse
- API to develop customized client experience
