Default legend values in result window
Hi all,
Is it possible to assign default legend values in the result window?
When looking at the stress results of an analysis, the highest legend value is by default set to the largest stress in the model. As this often occurs near a singularity, the biggest part of the model is dark blue. I usually change the min value to 0 and the max value to the yield stress.
I know I can use result templates. Is it also possible without a template by just changing the defaults?
I'm using Simulate 3.0.
Best regards,
Wouter
