Drawing showing negative dimensions
I have a group of users (our Tool Design dept) that experiencing something I've never seen before.
When 5 of the 6 people open a particular drawing, everything appears correctly.
When the other guy opens the same file, a bunch of dimensions show as negative values. If he opens the properties window for one of these dims they show, for example, -2.00. If he removes the negative, the features fly off the part. These neg value dimensions only appear on one sheet and only show up on two parts. They also don't show in every dimension for those particular features.
The features are not created off a coordinate system, nor are they referencing datum planes. Not that this should matter in my experience.
I've tried looking for configs that may alter this, but can't find anything. Plus, he doesn't have a local config anyway.
So short of tech support, which is going to want the file and I'm reluctant to go through those hoops just yet,
