Family table: mass in repeat region
  • September 3, 2015
  • 2 replies
  • 3535 views
I have seen other posts and tried them with no success.
Does anyone have a suggestion on how to display on a drawing repeat region the Mass of each individual item on a family table.
Currently I thought &fam.inst.param.name == mass would work.
Aric,
I think that you have to add "MASS" parameter column into family table and enter its values manually. I can't imagine any automatic solution...
Martin Hanak
In each of our parts and assemblies we have a parameter called mass as a real number
This is in the template so it gets populated at each new model generated.
in each of our parts we have a relation:
/** mass properties of the part file
mass=mp_mass("")
volume=mp_volume("")
surf_area=mp_surf_area("")
cgx=mp_cg_x("","c-x0y0z0","") /* may vary based on part csys name
cgy=mp_cg_y("","c-x0y0z0","") /* may vary based on part csys name
cgz=mp_cg_z("","c-x0y0z0","") /* may vary based on part csys name
/** end of mass properties of part file
in each of our assemblies we have a relation:
/** mass properties of the assembly file
mass=mp_mass("")
cgx=mp_cg_x("","asy_csys_def","") /* may vary based on assy csys name
cgy=mp_cg_y("","asy_csys_def","") /* may vary based on assy csys name
cgz=mp_cg_z("","asy_csys_def","") /* may vary based on assy csys name
/** end mass properties of the assembly file
In your bom table, add a column with a report parameter &asm.mbr.mass
based upon your bom table, it will report accordingly.
(qualification statement - at least mine does....)
ron
Family table instances behave differently than standalone parts and assemblies.  Take a look at this article from PTC tech support on how to create a repeat region that correctly updates and displays the mass for family table instances.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS143060
Tom,
thanks for sending the link. I have tested CS143060 procedure in CR2 M070 and it works well. Just one additional note: All family table instances must be verified. The verification process puts correct values into weight column.
Martin Hanak
I wasn't real keen on setting the config option "mass_property_calculate" to "automatic".  This could cause serious performance issues when working on large assemblies.  I think I would turn it on just long enough to have the family table's mass value calculated, then turn it off when done.  The last calculated value will remain in the table, even with the option off.
