How to route several wire/cable simultaneously (pro/cabling)
Hello. I have some difficulty with pro/cabling. I would like route several cable from several connector, and i would like use a bundle (without sheath). My problem : impossible to join all wire/cable in the bundle. When i select wire/cable to route, i select entry port and pro/cabling write :"Cannot route more than one cable to WIRE entry port" Should be select several entry port, but pro/cabling don't suggest this. If you have a idea for join several wire/cable, I'd be EXTREMELY grateful.
