I need help with wildfire 3.0 m000
Hi, My company recently found out we could upgrade from wildfire 2.0 to wildfire 3.0. after doing so now i have lost the control for line weight in a pdf doc. I had the config file set up in 2.0 pdf_use_pentable yes however this does not work in 3.0 m000 i have read in later versions that it is fixed. is there anyway i can either control the line weight for pdf's in 3.0 m000 or upgrade for free to m020 where i think this problem was fixed?
thanks...
also I know I can print to pdf and control it that way the problem with that is the other guy i am working with can never get it right no matter how many times i show him. sop every time he makes a pdf which is 30+ times a day i have to do it for him....
