Parameter UI Custom Order
I save and use a parameter config file.
Config.pro option (parameter_dialog_setup_file \path\rp_config.xml)
In the rp_config.xml file, can you specify the exact order to sort the names?
Currently the rp_config file has:
- <sortby>
<column name="name" order="Descend"/>
I would like to list the names in an order that suits my needs
IE. <sortby>
<column name="name" order="name1,name2,name3,name4"/>
Jeff Lippeth ▪ Mold Design Engineer
NyproMold, Inc.
955 Tri-State Parkway, Gurnee IL 60031
144 Pleasant St, Clinton MA 01510 ▪ www.nypromold.com
- <sortby>
IE. <sortby>
NyproMold, Inc.
