pen colors
- 19 replies
- 12515 views
- Translate All
I have read reams of suggestions on printing and pen tables - so much so that I have lost track of all the helpful information. Many of these strings are closed....
I see you have offered help with pen tables previously so I am hoping you can steer me in the right direction.
I have nearly what I want without a pen table when I export to pdf (color, use pen table)
my quilts are exporting as yellow and I would prefer them to be black (thin lines)
So, instead of defining all the pens I was trying to just target the pen(s) that I thought were directed to quilts and quilt edges... Thus I tried a pen table that only assigned two pens thinking the rest would stay default.
pen 6 thickness .004 in; color 0.0 0.0 0.0; outer_quilt_edge
pen 8 thickness .004 in; color 0.0 0.0 0.0; quilt_color
This did in fact change my quilt edges to a thin black line but all other colors were lost - that is I have a red note that reads "CHECK PRINT" than now shows up as black in the pdf (lost red color)
Do I have to assign all the pens in order to change this one attribute or did I make some other mistake?
Thanks for being so helpful (and patient)
Scott
currently using M140 - creo 3.0
