Problem importing STEP
- 13 replies
- 13431 views
- Translate All
I’m trying to import a Cylinder ( 2 parts, Tube and Rod) into Creo 3.0. Problem is that it will not generate a Solid of it, when I try the same into Autodesk Inventor, it makes it a Solid no problem. Been trying Import Doctor, but not much Luck with model so far.
Anyone who have some good tips on how to do this?
Adding problematic Cylinders:
