Hi
I am trying to insert a note in a drawing that contains the symbol μ.
But it looks like a square symbol.
What am I doing wrong?
While you are in the 'note' function, hold down Alt and type in 230 you will get the symbol you need.
James
Copy the symbol from windows character map. I guess it would solve ur problem.
That is exactly what I am trying to do.
I copy text from a word document including the symbol.
But in Creo it turns to a square symbol.
Copy the symbol from windows character map, Start>All programs> accessories>system tools> character map, Try this.
James
Thank you, now it works!
