2 datum holes in hole table
reg901-25
I amworking on a drawing for a sheetmetal part which has approx. 50 holes in it. There are 2 sets of holes (each with approx. 25 holes). I would like to have a hole table which has 2 datum holes, one for each set of holes but I don't know if this is possible.
I have tried to solve the problem by creating 2 separate hole tables (which referenceseparatedrawing views)and deleting the holes I don't want in each table. I thought this had worked, but when the part design was changed (some holes were added/deleted)and I updated the hole table, allthe holes I had previously deleted in the table reappeared.
Any help would be appreciated!
Alan
Why not just make a pattern table where you choose the hole diameter in addition to the placement dimensions?
